Activity › Forums › Apple Final Cut Pro Legacy › Importing spanned files (over 2gb captures)
Posted by Neil Smith on April 4, 2008 at 3:55 pmHi
When FCP (v6.02) captures large clips and the filesize gets to 2Gb, it creates new files with the same name with a suffix of -1, -2 etc. If I try to import these captures into a new project, I get a File I/O error. I have tried this a couple of times now and it always does the same.
Any ideas?
Neil
Tom Brooks replied 18 years, 4 months ago 4 Members · 13 Replies -
Tom Brooks
April 4, 2008 at 9:44 pmWhat’s the format of your scratch disk? Media drives must be formatted Mac OS Extended.
Neil Smith
April 4, 2008 at 10:54 pmI work in a University and we use a network storage server (EditShare) and also the students have their own portable hard drives and this problem happens on both. Last time I tried it, a few months ago, I seem to recall copying the files onto the Mac’s hard drive and trying it from there too with no luck.
Max Chernyaev
April 5, 2008 at 2:21 amEditshare is a network drive. Final Cut treates any non-local drives as drives with no large file compatibility, so it write files spanning them by 2 GB.
To playback the movie you should open the first file in sequence (like [basename].mov; not [basename]-1.mov, etc.). Technically that file looks like a reference movie, you can check it in Movie Info in QuickTime (you’ll see references to the rest of your files).Good luck!
Neil Smith
April 5, 2008 at 9:15 amMax, thanks, but that doesn’t answer my problem. I can play them in Quicktime OK, but if I try to import the file(s) into FCP, I get a File I/O error
Tom Brooks
April 5, 2008 at 1:05 pmMax,
Thanks for explaining that network drive thing. Can the reference movie be made into a single self-contained movie by opening it in Quicktime Pro and doing a “Save-As” self contained? I’m not sure if this would solve Neil’s issue. The other thing to try is to simply limit the length of movies to stay under the 2GB limit–a very severe limitation to be sure.
-Tom -
Max Chernyaev
April 5, 2008 at 7:42 pmReally? When you drag the first file to a FinalCut window it reports a I/O error? Very strange, I always do it that way.
I guess one of these solutions may help:
1) Try copying all files (reference and referenced) to a local HFS+ drive and open. This might help if there are some network issues;
2) You say QT plays back the movie. So make a “save as” as a self-contained movie. You’ll get all files joined to one. If necessary you can save it even to a network Editshare drive, everything should be fine. -
Max Chernyaev
April 5, 2008 at 7:47 pmTom, FCP is doing exactly the same: force limiting max file size to 2GB if it cannot recognize the partition type. It’s a normal thing.
Yes, creating a single self-contained movie will solve the problem! -
Sabreena Peters
May 21, 2008 at 9:57 pmI did that before, but where in disk utility would it say it?
