Activity Forums Apple Final Cut Pro Legacy Importing SD Footage Shot on HVX 200
  • Importing SD Footage Shot on HVX 200
    Posted by Brent Curran on April 24, 2009 at 8:33 am
    Hi, I hope someone can’t point me in the right direction. It seem I’m having Difficulties finding out the best was to do what I’m doing. I Have SD footage that was shot on HVx 200.. The footage is 720×480 Squeezed or 16:9. Instead of using the gears on my Hvx to ingest footage I’m using a small cannon hand held. My question is When I ingest this way what is the best Fcp settings? I’m having problems with the finishes result after I edit and render out the footage. I’m getting low quality using the dvpro compresson. However when I use the H.264 everything is better but some where down the road I’m losing quality. The final out come will to have the footage on DVD and the internet. The ingesting part using the canon I have done before with great results. I’m looking for a simple clean effective way to ingest SD footage. I did ask the camera man if he shot 24p or 24pa. He said 24p.. So when I set up my project sequence to 23.98 I enter a clip into the editor and a message comes up saying I need a correct sequence match for video format. Hmm I click yes to change settings to match footage. Please can someone tell me what is the cleanest way to ingest footage in this manner.
    Brent Curran replied 17 years, 4 months ago 2 Members · 4 Replies
  • Doug Beal
    April 24, 2009 at 1:37 pm
    24P DV is 29.97 on tape. HVX in SD on tape is DV
    injest DV/DVCpro NTSC anamorphic. firewire basic for the canon
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
  • Brent Curran
    April 24, 2009 at 4:16 pm
    Ok, I’ve done this . Now I set my sequence setting In Fcp to be 29.97, lower field, 16:9 interlaced, Lower field dv/dvcpro compression on 100% quality.. I export using quick time conversion on the best setting ntsc dv/dvpro. It doesn’t look good. I export using h.264 and it looks fine. .. Now I’ve done this several times in the past exporting with ntsc dv/dvcpro and never had this problem. Could it be possible that I ingest the footage wrong? I looking to understand why the Dv/Dvcpro export using quick time conversion is doing this. Now to be honest I did ingest the footage using the hand held canon with fcp capture setting ntsc fire wire with advanced pulldown. could this be the real problem. If so why does it look great using the h.264 export?
  • Doug Beal
    April 25, 2009 at 4:54 am
    why are you using qt conversion. Just export “use current setting”
    If you need to generate other formats drop your export into compressor, it’s much cleaner and faster on a multicore machine
    Doug Beal
    Editor / Engineer
    Nashville TN
  • Brent Curran
    April 25, 2009 at 7:02 am
    you are awesome. It’s much faster and cleaner. Thanks a lot .. I just love all the things you can learn here on creative cow. People like you make it wonderful place to come and learn. I wish you all the best and if you want to check out some of my work. https://www.youtube.com/hidden3 Here is my you tube channel.
    I would love to look at some of yours. Thanks Doug …
