Activity › Forums › Avid Media Composer › Importing SD Footage into AVID
Posted by Timothy Lydon on April 9, 2014 at 11:01 pmHi all,
I have a quick question, wondering if anyone out there can assist me.
Last summer I shot some 720 x480 footage. Here are the codecs: DV/DVCPRO – NTSC, Linear PCM, Timecode.
What format should I create the project in? 720p 23.976? or 24p ntsc?
Also, how should I import the footage into Avid? Or should I AMA link?
Much thanks,
Timothy
Timothy Lydon replied 12 years, 4 months ago 2 Members · 8 Replies -
Ricky Barrow
April 10, 2014 at 12:16 pmWhat is the frame rate of the original? Is it anamorphic? Are you wanting to up-res to HD and if 4×3 (non-anamorphic) do you want pillarbox or pan and scan?
Hare are thoughts to consider:
Typically you should ingest into MC in a project type native to the footage (NTSC and frame rate) then change the format of your project to HD format or open that bin/footage from another project type you want to finalize.
If file based you should AMA link and transcode. If only going to DVD then stay in NTSC format.
Ricky
Timothy Lydon
April 10, 2014 at 3:43 pmRicky,
Thank you so much for responding…
The frame rate is 24fps and I do not know if it is anamorphic or not. How do I find that out? I do not want to make it HD, and I’m sorry but I don’t know what pillar box or pan and scan means.
This will not be going to DVD, I’m making a promotional video for a music festival and putting it on Youtube.
Timothy.
Ricky Barrow
April 10, 2014 at 6:05 pmCreate 24p NTSC project, AMA link and transcode. This will be progressive (perfect for computer/web.
NTSC (DV/DVCPro) is 720×480 pixels – this is 4×3 aspect ratio. If your video was shot anamorphic your video will look squeezed, everything will look tall and skinny – what this means is you can stretch it out to be visually correct at a 16×9 aspect ratio. If your video looks normal then it is standard 4×3.
I haven’t uploaded to youtube lately and don’t know if they stretch 4×3 to fit 16×9 (in which case you will need to add black pillar bars and export 16×9).
At any rate don’t get confused by that yet, just create project, link and transcode and edit etc. You can always come back to the forum for more info. on the next stumbling block!
Ricky
Timothy Lydon
April 14, 2014 at 11:04 pmThank you Ricky!
What would you transcode to?
Apple Pro Res
1:1 MXF
JnkNTSC
etc……This is where I often get confused, I’m not certain about the difference between these video resolutions.
Best,
Timothy
Timothy Lydon
April 15, 2014 at 1:53 pmGreat, is this a rule? Do you always transcode/import at this resolution?
Timothy
Ricky Barrow
April 15, 2014 at 2:08 pmNot really any rules per se – I have taken footage in at DV25 before … the general “rule”, if any, is that you want to keep the highest quality and resolution until the final step, in your case, until the final compression that happens when you transcode to MPG2 which is the spec for DVD. At the point of compression/transcoding, the quality or bit-rate will be limited/determined by: 1-Length of footage, 2-DVD 5(single layer) or DVD 9(dual layer0 3-Audio type (PCM or AC3). If your footage is short enough in length, your compression/transcoding will be limited by the DVD spec (roughly 9 MB/s) – in practice, it is recommended to never exceed 7.5 MB/s (generally aiming for 6.5-7 MB/s)
Ricky
