Activity › Forums › Apple Final Cut Pro Legacy › Importing Saved Droplets to Compressor
Posted by Tiffany Chung on September 3, 2010 at 9:53 pmI have several Compressor droplet settings (at least 10) from my client’s computer that I need to import into my Mac so that I can work remotely. I’ve read that it’s not possible? But I’m hoping it is possible. I mean there’s an option to save the droplets, right? So, why can’t we import those saved droplets to another computer? Is there no way to do so? Or is it a convoluted process? Please help! Many thanks in advance. I really would rather not have to manually create each and every droplet setting.
Alan Bezet replied 15 years, 10 months ago 7 Members · 7 Replies -
Liam Lawyer
September 3, 2010 at 10:29 pmDon\’t think it is possible, but any reason you can\’t use the droplets? The only time I have seen an issue with this is when you are on diff version of compressor.
Liam Lawyer
-editor- -
Tiffany Chung
September 3, 2010 at 11:23 pmI’ve got the same Compressor version as the client’s. =(
Now, I don’t fully understand the concept about saving droplets if they’re already saved in the settings. What would you do with saved droplets if you can’t even open/import them into Compressor on other computers?
Well, thank you for your response and help anyway, Liam.
Paul Figgiani
September 4, 2010 at 2:14 amTiffany,
Try this:
Copy the Droplets to the target machine. Right click each Droplet/Show Package Contents.
You will find the Preset file located in the “Settings” folder.
Drag the Preset file into the Compressor Preset window. Create new Droplets from the imported Preset files.
-paul.
Dan Monro
September 4, 2010 at 2:42 pmPaul’s instructions are perfect if you need to change the droplet. If you can use it as is, you can do that without re-importing them into compressor. As long as its the same version, you should be able to copy the droplet from the client’s machine to yours. You can put them in your documents folder, or any other folder you choose. Then for convenience, make an alias for your desktop. The you can drop a file directly onto the alias and it will run the droplet (take a step further and turn off the confirmation dialog.)
Cheers,
DDan Monro
FCP, Avid, AfterFX, Atlanta
MacBook Pro 2.4 GHz Intel Core 2 Duo 2 GB ram
Mac OS X 10.5.8
GeForce 8600M GT Final Cut Pro 7.0 Quicktime 7.6.6
– OR –
2 x 3.2 Quad Xeon; 16 GB ram
Mac OS X 10.6.4
NVIDIA Quadro FX 5600 Final Cut Pro 7.0.2 Quicktime 7.6.6 -
Alan Bezet
November 22, 2010 at 10:07 pmWow… THANK YOU! I had created a very special droplet to fit 2 hours of down sampled HD material onto an SD DVD for another project. It took me a day and half to find the perfect settings and I’ve been trying for awhile to try and salvage the Droplet, so I can re-tweak the settings.
Thanks a lot!
David Roth weiss
November 22, 2010 at 11:15 pmDroplets are a vastly under-used and under-appreciated tool in FCS. They are quite powerful, and huge timesavers.
Take the time to get it exactly right, and once you do, make sure to save it in a spot where you find it for the next time. You’ll be glad you did…
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Alan Bezet
November 23, 2010 at 12:06 amOh I never lost the droplet. I just failed to save it as a setting and I needed to tweak the setting that I had so painstakingly created, but you can’t change a droplet.
Now I know how.
Alan Bezet
Production Manager
Washington, D.C.
alan.bezet@gmail.com
