Activity › Forums › Adobe Premiere Pro › Importing R3D Shot/Scene metadata into Premiere?
  • Importing R3D Shot/Scene metadata into Premiere?
    Posted by Matthew Rogers on March 14, 2013 at 3:44 pm
    Hey, so I did a shoot last week where my DIT put the scene and shot info in the respective metadata fields in RedCine-X Pro because we both figured that was a metadata standard which Premiere would read. On opening the files today we found that not to be true (Premiere 6.0.0). Is there any way to quickly and efficiently get that metadata into Premiere so it’s actually useful? I know I can export a .csv file which has all the info I need, but not sure how to get it into Premiere without manually typing it. Would Prelude be of any help? Can Prelude even let you put in metadata on R3D files these days?
    Thanks.
    Angelo Lorenzo replied 13 years, 6 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    March 15, 2013 at 7:55 am
    I answered your post on RedUser, but for the benefit of others I’m duplicating my answer here.
    1. In Redcine-X take all of your files and add them to a project bin
    2. Add all of your videos to a sequence in Redcine-X (don’t worry about it being perfect, this step is really a technicality)
    3. In Redcine-X’s project browser where you see your bins and sequences, make sure the sequence you just created is selected
    4. Shallow export a Final Cut XML
    5. Import XML into Premiere and relink R3D files.
    You should see metadata populate within Premiere. This metadata is project specific and is housed in your Premiere Pro project file so any new projects will have to go through these steps.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
