Activity Forums Adobe Premiere Pro Importing quicktime movies into Adobe error
  • Importing quicktime movies into Adobe error
    Posted by David Mcguire on May 5, 2009 at 8:33 pm
    I have imported and edited sequences in FCP Studio in the field on my MacBook Pro and would like to import the movies into Adobe CS3- on another machine (PC Intel Duo- running Adobe Premiere Pro CS3) to assemble a film with other footage taken with an SD camera.
    When I export the movies from the Mac using varous settings using compressor or as a quicktime movie I cannot import them into Premiere. I receive an error message file format not supported.
    What would be the best file settings to import so Premiere Pro can see them? Avi doesnt work- they are pixelated when imported into adobe CS3.
    thank you
    David McGuire
    Seastewards.org
    Media for a Healthy Ocean
    Charles Kafoure replied 17 years, 4 months ago 4 Members · 4 Replies
  • Vincent Rosati
    May 5, 2009 at 11:13 pm
    There’s probably a better answer than this, but I seem to remember doing something like this in the past.
    I eventually used After Effects to do the conversion, and it worked fine. I’m not exactly sure why AE would be better at cross-platform translation, but it worked.
    As always, video codec (AVI or MOV) Uncompressed.
    Vince
  • David Mcguire
    May 6, 2009 at 3:41 am
    Hi Vincent
    thank you for the response. I tried to open in AE but it would not open. If I convert to avi then I lose quality to a point of low quality.
    There must be a workflow but I havent found it.
    thanks again
    David
    David McGuire
    Seastewards.org
  • Eddie Lotter
    May 6, 2009 at 1:40 pm
    [David McGuire] “then I lose quality”
    Not if you do what Vincent said. Use no codec (uncompressed) or use a lossless codec and you cannot lose quality.
    See also: FAQ:How do I convert my files?
    Cheers
    Eddie
  • Charles Kafoure
    May 8, 2009 at 6:11 pm
    I am using Premiere Pro CS3 (novice user) on a Mac. When I find a file created from an import to iMovie from mini-DV, it is grayed out. I am confused.
    Charlie
