Activity › Forums › Adobe Premiere Pro › Importing Quicktime move with right settings details below. Premiere Pro CS5
  • Importing Quicktime move with right settings details below. Premiere Pro CS5
    Posted by Steve Mac kenzie on April 18, 2012 at 7:08 pm
    I have to clips that make a feature length movie that have been encoded for me at a post house and I just need to put them together and burn them to DVD. This issue is that I can see the interlacing in the footage during certain scenes and through transitions. The title crawl at the end jumps a bit as well. The specs for the clips are below. The eventual destination is DVD through Encore. I have done mostly episodic work batched from tapes so I have never had to deal with this.
    Here is the clips properties.
    Quicktime Movie
    Image Size 720 X 486
    Pixel Depth 24
    Frame Rate 29.97
    Average Data Rate 27.2 MB/second
    Average Frame Rate 29.98 FPS
    Uncompressed 10 bit.
    Thank you for your time and your help!
    Steve Mac kenzie replied 14 years, 5 months ago 2 Members · 3 Replies
  • Steve Mac kenzie
    April 18, 2012 at 7:54 pm
    This is a PC based system. It was purpose built for editing.
    Thank You for your input!
  • Eric Jurgenson
    April 19, 2012 at 1:01 pm
    Have you looked at it on an interlaced (broadcast) monitor? (You need a video I/O card to do this, unless you want to export to a DVD, and play that on a regular TV).
    Computer monitors are not interlaced, and can show interlace artifacts that might not show on an interlaced monitor.
  • Steve Mac kenzie
    April 19, 2012 at 4:25 pm
    I have burned the footage various ways and watched it on a television. Unfortunately the problems are showing that way too.
