Activity Forums Apple Final Cut Pro Legacy importing quicktime into fcp5
  • importing quicktime into fcp5
    Posted by Mark Fason on September 16, 2005 at 3:13 am
    i’m currently working on an fcp5/dvcpro hd 720p/60 documentary that has an abundance of stock footage. most of the footage is coming from the stock house as quicktime files that are small. i’ve tried to cut them into a sequence and use ‘scale to sequence’ to resize them but the rendering is taking a lot longer than i expected on my dual processor g5. is there any way to resize them once(possibly convert in quicktime pro with some hd codec and then export) and make them a clip that final cut could use without extensive rendering?
    thanks, mark
    Kathy replied 21 years ago 3 Members · 2 Replies
  • Jerry Hofmann
    September 16, 2005 at 3:33 am
    Try using Apple’s Convertions in Compressor 2 for this. QT Pro can do it too, probably similar results?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Kathy
    September 16, 2005 at 2:02 pm
    Sounds like you haven’t been sent the final clips, only the try outs. Ask the stock house to send you the correct size.
    kathy
