Activity Forums Apple Final Cut Pro Legacy importing quicktime file into FCP doesn”t work
  • importing quicktime file into FCP doesn”t work
    Posted by Jonomaloney on November 20, 2007 at 10:13 pm
    Hi All,
    I was given a dvd of a video that I need to pull the files from and edit into a different project.
    So I copied the Video_TS folder from the DVD to my hard drive.
    Then I converted the .VOB files to Mpeg4 using Handbrake.
    The new mpeg4 files open and work in Quicktime.
    But when in FCP I ask it to import the mpeg4 files and it does not work. Why?
    FCP says this when I try to import:
    “File error: 1 file recognized, 0 access denied, 1 unknown”
    When I try to open it in FCP instead of importing it, FCP says:
    “Final Cut Pro does not support this frame rate or the way it is represented.”
    But when in Handbrake I set the settings to 29.97 framerate with the Quicktime presets.
    Does anyone know how I can fix this and/or know of another program like handbrake that I can download for free that will convert .VOB files to mpeg files that FCP will support?
    Thanks for all the help!
    Jon
    13 replied 18 years, 9 months ago 2 Members · 1 Reply
  • 13 Create COW Profile Image
    13
    November 20, 2007 at 11:19 pm
    [jonomaloney] “I was given a dvd of a video that I need to pull the files from and edit into a different project.
    But when in FCP I ask it to import the mpeg4 files and it does not work. Why? “
    Hand break makes HIGLY compressed files that are fine for watching but NOT fine for editing.
    If you have any more questions please do a search first.
    The topic of your question is covered at least once a week here on the cow, you will find plenty of info with a search.
