Activity Forums Avid Media Composer Importing Quicktime and Photoshop into Avid XPress Pro
  • Importing Quicktime and Photoshop into Avid XPress Pro
    Posted by Stefani Natalia on May 13, 2005 at 3:17 am
    Help!! I have a serious problem in importing Quicktime and Photoshop files into Avid. The files contains a lot of text and lines. In Avid, they look very pixelated and the aspect ratio is a little bit squeezed. I have changed the import settings to each available option but the video/graphics still looks very bad. Is it actually bad or is it just the preview that is in low res? How do you fix it???
    J Smith replied 21 years, 3 months ago 3 Members · 4 Replies
  • Earle Nichol
    May 13, 2005 at 4:30 am
    Hey Natalia,, I think we need more info. First of all, what size are your graphics that you’re importing? I use the import settings everyday and it’s usually very reliable. Are you working at 1:1 or DV 25 or 15s. Have you rendered your graphics for playout?
    Let us know…
  • Stefani Natalia
    May 14, 2005 at 2:41 am
    The graphic size is 720 x 486. In After Effects, I use non-square pixel. In Avid, I work at DV 25. On the clip, I don’t see a green or blue circle so I assume that it doesn’t need to be rendered.
  • J Smith
    May 14, 2005 at 7:22 am
    DV is 720 x 480, not 720 x 486 – that’s D1.
  • J Smith
    May 14, 2005 at 7:25 am
    I should add that Avid’s scaling is (in my experience) quite bad. Not sure if that’s your problem–but try feeding it 480. I’m thinking it will like that much better.
    good luck.
