Activity Forums Avid Media Composer Importing Quick Times with Alpha from AE into Avid
  • Importing Quick Times with Alpha from AE into Avid
    Posted by David Fleury on September 8, 2007 at 4:53 am
    Can anybody clue me in to this process, i.e. output settings from AE and import settings into Avid?
    I can get it to work by exporting my AE comps as Tiff sequences but I have no luck at all with QT.
    When I get my QT into Avid it reads the whole frame as the Alpha Channel.
    I’ve spent two days with different export / import settings with no luck. I must be missing something VERY obvious.
    thanks in advance
    David Fleury replied 19 years ago 3 Members · 5 Replies
  • John M. rice
    September 9, 2007 at 3:20 am
    In Avid when you import, try the “reverse” option on the alpha import settings. When I export a QT out of After Effects for Avid that option always works. If you have already tried just let me know and I can provide more specifics, but that usually is the issue.
  • Grinner Hester
    September 9, 2007 at 2:34 pm
    you have to invert the alpha in your imnport settings for images and image sequences. You’ll maintain alpha with QTs.
  • David Fleury
    September 9, 2007 at 6:10 pm
    Hey everybody, Thanks for the replies. I have already tried inverting the alpha channel and that seemed to make no difference.
    I posted this question in the AE forum as well and got a response there about rendering with the Avid codec, which I am doing.
    I am going to try that suggestion tommorow morning to see if it works. I will post it as the solution if it works.
  • Grinner Hester
    September 10, 2007 at 5:29 am
    your nor using an avid codec now?
    This wot affect your alpha but will highly increase your import times.
  • David Fleury
    September 12, 2007 at 1:27 am
    Switching to the Animation codec did the trick.
