Activity › Forums › Adobe After Effects › importing .qtl
importing .qtl
Posted by Joshua Stanley on June 20, 2005 at 4:49 pmI just dowloaded a quicktime video with thte extension. qtl and I cant import it into AE or FCP Anyone know about this file? Anything I can do to get it into AE? Thanks in advance.
Josh
Joshua Stanley replied 21 years, 3 months ago 3 Members · 5 Replies -
Rob Montague
June 20, 2005 at 4:56 pmWhat’s the link you downloaded it from? I’ll take a look and see if it can be imported or converted.
Joshua Stanley
June 20, 2005 at 5:21 pm -
Steve Roberts
June 20, 2005 at 5:30 pmIt seems to be YUV 16-bits.
https://www.graphics-converter-pro.com/500.htmSorry, can’t help more.
Steve -
Rob Montague
June 20, 2005 at 5:57 pmA .qtl file is a QuickTime link file. Basically it’s an XML-based pointer/reference type of file that will launch a QuickTime movie file in QuickTime player (as opposed to using the QuickTime browser plugin.) One application would be to prevent hijacking by another player.
For more info, check out:
https://developer.apple.com/documentation/QuickTime/QT4WebPage/samplechap/special-11.htmlhttps://developer.apple.com/documentation/QuickTime/QT6WhatsNew/Chap1/chapter_1_section_53.html
and
https://www.quicktiming.org/tutorials/qt_web1.php
down at the bottom, under “Launching QuickTime Player from a Text Link or
Graphic”I don’t believe you can’t directly import a QuickTime link file because it’s simply a text file that points to the actual QuickTime movie file itself (open the .qtl link file in a text editor and you’ll see.) You’ll need to “Save As” or “Export (which I think requires that QuickTime Pro be registered, in order to unlock those features) from QuickTime Player once the master movie file has been loaded, to save that file out.
Also, as a friendly footnote from one pro to another, I’m sure I don’t need to point out the Beeb’s licensing guidelines:
https://www.bbcmotiongallery.com/customer/common/help/helpLicenseTips.jsp-R.
Joshua Stanley
June 20, 2005 at 6:06 pmRob thanks for the info. Yeah I was just interested in inserting some footage for a rough cut before I decide whether to purchse.
Josh
