Activity › Forums › Adobe After Effects › Importing PSD vs PNG files
  • Importing PSD vs PNG files
    Posted by Andy Kelly on October 20, 2014 at 6:20 pm
    Hello!
    I’m animating a very large, multi-layered PSD in After Effects. It’s currently all imported directly from the PSD file (as footage). I was wondering if it would be less of a load on my computer’s memory if I just saved every layer as a PNG and imported them to After Effects then. It would be a little more work upfront for me, but I’m wondering if doing so will save time in playback loading times.
    So does anyone know if there’s a difference in size and how the program reads these files? Or if there are any alternatives that would increase efficiency?
    Bart Stevens replied 11 years, 11 months ago 2 Members · 1 Reply
  • Bart Stevens
    October 21, 2014 at 12:45 am
    I’ve had some similar experience with using really large “for print” files, and always try to keep my sub-comps to only the needed resolution.
    For example if I had a 12000×7000 pixel .psd file, and I only needed to use a 600×600 area of that image, I would make sure my sub-comp is only at that needed resolution.
    Import composition “retain layer sizes” is nice feature to break apart a large .psd files. and have each element with its own center.
    Hopefully that helps.
