Activity Forums Maxon Cinema 4D Importing PSD files into a Cinema 4D scene.
  • Importing PSD files into a Cinema 4D scene.
    Posted by Javier Lopez on January 13, 2015 at 2:24 am
    Hello,
    I am working on a Cinema 4D scene and I have several pictures in PSD format, the pictures are from objects that I want to include on the scene, so I had deleted the elements that I don’t want from the picture leaving transparency around the object resulting on a PSD file, now I had created a plane in the C4D scene and a new material with the PSD file in the transparency channel, but when I render the edges of the plane are present creating a shadow around the plane itself, any advise on this issue?. Please take a look at the following picture.
    Thanks.
    Brian Jones replied 11 years, 7 months ago 2 Members · 3 Replies
  • Brian Jones
    January 13, 2015 at 3:11 am
    you want to use the Alpha channel instead. Load your image in the Color channel and the Alpha channel
  • Javier Lopez
    January 13, 2015 at 3:44 pm
    Hello Brian,
    Thanks for the help, I had tried what su suggest but still having the problem, I found out that the whole situation is the plane reacting to the ambient occlusion, even when the plane is invisible and just the picture is visible, is there a way to have the picture interact with he ambient occlusion? or since the picture is in the plane there ir no way to avoid it?.
    Thanks.
  • Brian Jones
    January 13, 2015 at 4:11 pm
    you can exclude the plane from AO by adding a Compositing tag to the plane and unchecking Seen by AO
