Activity Forums Adobe After Effects Importing problems in After Effects 7/CS3 (Canon A710)
  • Importing problems in After Effects 7/CS3 (Canon A710)
    Posted by Daniel Lamount on October 21, 2009 at 7:57 am
    So, don’t know were to put this post but the main problem is however that I can’t seem to import my footage from my small camera anymore! After an uppgrade from AE7 to AECS3 the footage are all messed up in thin vertical lines in all colours. And when uninstalling CS3 to reinstall AE7 again, as an effort to reset the problem, there’s no change!
    Now I know importing (or even working with) these sort of formats in AE are not exactly recomended, however my point is it worked just fine before the upgrade! And importing MPEG1/MPEG2 doesn´t work either as it did well before! One funny thing is that footage from my old camera with same type of compression (I beleive HDYC) show up just fine (!!?). So what’s this all about?
    Also I suspect issues with the K-Lite Codec pack but not sure as I keep getting a message at start up saying “Quitime will be disabled [..] campatible vs was not found”. K-Lite was somewhat reasently installed before the uppgrade but I can’t seem to find any specific when searching the forum though.
    Otherwiswe, “normal” uncompressed files seem to work as usual (avi). So, anyone have any ideas?
    Daniel Lamount replied 16 years, 11 months ago 2 Members · 7 Replies
  • 7 Replies
  • Chris Wright
    October 21, 2009 at 8:14 am
    Your suspicions are correct, ffdshow is disabling the good codec. It’s called fflib or something in the video codec tab of ffdshow.
    https://technicolorsoftware.hostzi.com/
  • Daniel Lamount
    October 21, 2009 at 9:17 pm
    AHA! Ok, well that would explain a lot! Is there a way around this (dissable the ffdshow codecs?) or do I have to uninstall the codec pack?
    Otherwise, thanx a bunch! This forum seem… HUGE!!
  • Chris Wright
    October 21, 2009 at 9:21 pm
    You can disable individual codecs by going to the tab and dropdown click disabled in video codec box of ffdshow filters.
  • Daniel Lamount
    October 21, 2009 at 10:21 pm
    Ok, I tried disabled the ffdshow in the “configure” tab and there were no change! I also uninstalled the K-Lite codecpack and reinstalled (the older, previously always working!) ACE Mega Codec Pack, restarting windows and tried importing after each change, and that didn’t work either! (Curently using AE7). I also tried importing in Premiere 2.0 with same results!
    The only good thing is that the start up message dissapeared so QT now obviously seem to work!
    What could this be?
  • Daniel Lamount
    October 21, 2009 at 10:58 pm
    What could this be?
  • Chris Wright
    October 22, 2009 at 1:51 am
    Sounds like the uninstall did not unregister some of the codecs. You can view all directshow codecs and remove selected with the free codec sniper.
    Also you will have to find out what codec your camera uses and possibly repair quicktime. I’m not standing at your computer so I can only guess. 🙂
    https://www.softpedia.com/get/Multimedia/Video/Codec-Packs-Video-Codecs/Codec-Sniper.shtml
  • Daniel Lamount
    October 22, 2009 at 8:22 am
    Oh sorry, not my intention making people frustrated =) !
    However, I’ve seem to have solved the problem! K-Lite (2009) doesn’t support MJPEG (couldn’t find it in the list anyway) which is the (footage) format of my Camera (Canon PowerShot A710 IS). So I complemeted K-Lite with Pegasus MJPEG PicVideo v3.0 Codec and that solved it! And for all you other people who might come across this issue, this is what it looks like!
    https://www.flickr.com/photos/22994228@N08/
    ..unfortunatly CodecSniper didn’t work all that good though! =)
    QuickTime Alternative also seem to have solved the start-up message I mentioned before. However, I haven’t tried importing any mov-files yet so I can’t say for sure.
    What remains is this….
    https://forums.creativecow.net/thread/2/893809#893809
    Funny thing is that for some reason I do get Premiere to import the MPEGs but NOT AE (AE7). Then again, this is obviously a different thread.
    Anyway…
    THANX CHRIS!!
    SniperError2
