Activity Forums Avid Media Composer importing problem
  • importing problem
    Posted by Baskar Sivakumar on September 24, 2018 at 7:13 am
    Hi,friends
    I should work with my *Mp4* files in Avid media composer but i cannot import my files *is there any way to import my Mp4 files in avid*……..thanks
    Shane Ross replied 7 years, 11 months ago 3 Members · 2 Replies
  • Michael Phillips
    September 24, 2018 at 12:55 pm
    Importing for video media is becoming a thing of the past as many codecs require a certain plug-in to link to beforehand using AMA. AMA linking is faster than import but has the one extra step. Link, then transcode to your desired target codec/data rate. Even the small extra step is faster as transcoding uses all cores to create new media versus the single core import uses.
    Michael
  • Shane Ross
    September 24, 2018 at 3:44 pm
    And in the most recent versions, this is done via the SOURCE BROWSER. Make sure the LINK option is chosen (lower left) and then when it’s in a bin, you transcode to a DNx codec for editing.
    Shane
    Little Frog Post
