Activity Forums Adobe After Effects Importing problem.
  • Importing problem.
    Posted by Gerome Myers on July 16, 2011 at 4:12 pm
    Hey, I need some help, This first time Im having a problem with AE and dont know what to do.. hope the best community in world can help! xD
    I have a movie in avi format that I imported to a editing software.. and I cut out some scenes and rendered them one at a time into seperate .wma 720 hd files.. because there was no option to make avi.
    When I import them to AE now it says //interpret footage// the item has an unlabeled alpha channel.
    And it gets imported but I cant work with it.. when i select it it says //AFTER EFFECTS ERROR 4// reading frame from file//
    im using after effects CS5.5
    I tried converting the wma file to avi and i could import the video into after effects now but its just a black screen video without any sound.
    Michael Szalapski replied 15 years, 1 month ago 3 Members · 5 Replies
  • Sascha Engel
    July 16, 2011 at 8:17 pm
    Need much more info: What editing software? What AVI file? Frame size, screen size & fps and so on.
    What export options you have from that software?
    Why into wma?
    Try to be more specific about all the tech specs.
    Sascha
  • Gerome Myers
    July 16, 2011 at 8:43 pm
    frame width> 464
    frame height> 256
    frame rate> 25 per sec
    Not sure how to find more info about the avi file.
    and the video editing software I used was COREL VIDEOSTUDIO PRO X4.
    I dont know why I cant render into avi but i can do to>
    MPEG>DV>HDV>DVD>AVCHD>BLURAY>WMV>FLV>CUSTOM
    when i do custom it will be a MPEG.
  • Gerome Myers
    July 18, 2011 at 5:44 pm
    Please, Im really at worlds end of what to do..
    If no one knows what the problem is.. Id be grateful for anything you think I should do.
    I really, really need this..
    I just cant think of anything at all to do.
  • Sascha Engel
    July 18, 2011 at 7:00 pm
    You have to try to be more specific: Why you first put it into the editing software?
    Why not immediately into AE (because I am not sure what you are editing on is a pro software).
    Why exporting it into several bits? And why into wma?
    People here want to help, but you need to be more specific.
    Explain each step – precies – and try to give all tech specs available to you.
    Sascha
  • Michael Szalapski
    July 19, 2011 at 2:15 pm
    Render it as an MPEG or some of the other options. Why the odd frame size?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
