Activity › Forums › Adobe After Effects › importing (prepareing) illustrator cs2 paths for AE and Zaxwerks
  • importing (prepareing) illustrator cs2 paths for AE and Zaxwerks
    Posted by Matt Stoltz on June 23, 2005 at 11:17 pm
    hey all I have a logo that i made paths around in ill so i could use invig on it –well i know you have to save ill files as ill 8 for invig but do u save as ai or eps –cause all i get in invig is an error saying –sorry no vector paths found
    I was also thinking there is something i have to change in my ill prefs??
    any help
    matt
    John Dickinson replied 21 years, 3 months ago 2 Members · 3 Replies
  • John Dickinson
    June 23, 2005 at 11:56 pm
    I haven’t tried with CS2 yet but 3D Invigorator can use CS files saved in Illustrator format. What version of Invigorator are you using? You can also save as version 8 but make sure it’s an AI file not an EPS. If you are still having problems email me the file and I’ll check it out. john@motionworks.com.au.
    JD
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Matt Stoltz
    June 24, 2005 at 3:26 am
    hey john thanks for posting –i have invig 4 –it still works the same –i figured it out — i made my paths but i didnt have them filled so invig wasnt seeing anything –after i filled them it worked fine –but now i have a nother question —
    trying to use AE 3d cam on object –well my 3d perspective is dissappearing –ive done this before but i cant remember what i did –when using the AE cam how do i keep the 3d of the object when i move the cam around
    matt
  • John Dickinson
    June 24, 2005 at 3:54 am
    Sounds like you have the 3D switch active for the Invigorator layer… if so, turn it off.
    John Dickinson
    Motionworks
