Activity › Forums › Adobe After Effects › Importing Premiere sequences into AE CS4
  • Importing Premiere sequences into AE CS4
    Posted by Amit Zinman on August 21, 2009 at 5:27 am
    So I see that sequences can be imported, but for some reason I can only import one at a time, and I have 46 in one project.
    Can I import all of them using a script of some menu option that I am missing?
    Amit
    Amit Zinman replied 17 years, 1 month ago 2 Members · 2 Replies
  • Todd Kopriva
    August 21, 2009 at 5:53 am
    There are quite a few ways to move data between After Effects and Premiere Pro. Which way you should use depends on what you’re doing. If you’re importing 46 sequences, you might want to try importing a whole Premiere Pro project.
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Amit Zinman
    August 21, 2009 at 5:55 am
    but then it imports all the cuts and effects. I just want the sequences as they come
