Activity Forums Adobe After Effects Importing Premiere Pro Project into After Effects issues
  • Importing Premiere Pro Project into After Effects issues
    Posted by David Mathis on July 7, 2011 at 8:56 pm
    I am new to Premiere Pro and After Effects after switching from Final Cut Studio 3 and I have a question. I have an issue with After Effects not correctly reading my blend modes from a Premiere Project that I have done. Instead of the blend mode showing up under the mode section in AE all I get is “-“. The same thing with the “T” switch. Is there something I am doing wrong or is there some glitch or bug I don’t know about?
    System details
    iMac (not sure what kind but will research if need be)
    OS 10.6.3
    Adobe Production Premium 5.0
    Also have Avid MC 5.5 and FCS 3 installed on same system
    Any advice or suggestions are greatly appreciated and thank you for such a great forum!
    David Mathis replied 15 years, 1 month ago 2 Members · 2 Replies
  • Todd Kopriva
    July 7, 2011 at 10:21 pm
    I just tried a simple test, and it worked fine for me. To determine why it’s not working for you, we’ll need a lot more information.
    To start, please post some screenshots to show exactly how you have your sequence set up in Premiere Pro (including showing the Effect Controls panel for a clip with a blending mode) and what the respective composition looks like in After Effects.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • David Mathis
    July 9, 2011 at 3:13 am
    I did a clean re-install of OS 10.6.3 and the Production Premium CS5 which cleared up the preservation and conversion of blend mode issues on QT movies but the problem now persists with still images. I have also tried copying and pasting my sequence between PPro and AE. I will send screen shots of what is going on, this is confusing.
