Activity Forums Adobe Premiere Pro Importing .png from photoshop
  • Importing .png from photoshop
    Posted by John Watts on May 30, 2019 at 7:35 pm
    Using PPRO 13.1 and photoshop 19.1.5.
    After my upgrade to PPRO 13.1 I have had trouble importing simple .png files made in photoshop. Nothing fancy, just lower thirds, merge visible and save as a .png. It has always worked in the past, now, I get invalid format warnings in PPRO. And it’s intermittent as well.
    If I jump through more stages and make them into .tif files they work. But, would like to get back to the faster workflow.
    Has anyone had this issue?
    TIA
    John Watts
    Premiere Pro Version 13.1
    2017 iMac (Retina 5K 27 inch) 1TB SSD
    4GHZ Intel Core i7
    32GB 1867 MHz DDR3
    Graphics AMD Radeon R9 M395X 4096 MB
    macOS Mojave 10.14
    Paul Neumann replied 7 years, 3 months ago 3 Members · 3 Replies
  • Jon Doughtie
    May 30, 2019 at 8:05 pm
    This may not be it, but the first two things I check are colorspace (must be RGB 8-bit, not CMYK or anything else), and that the PNG’s were saved uncompressed.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
  • John Watts
    May 30, 2019 at 8:45 pm
    Yes, 8 bit RGB
    The options when saving include: PNG File Format Options, Large size (with an check box for interlace..which I DO NOT select). Medium size and Small size. No real compression choice per say…
    For the moment the files are working. We’ll see if it raises it’s ugly head again later in the week.
    John Watts
    4GHZ Intel Core i7
    32GB 1867 MHz DDR3
    macOS Mojave 10.14
  • Paul Neumann
    May 31, 2019 at 7:08 pm
    I only saw this on Mac. None of the PCs showed this problem. My way around it was just to bring the graphics in as a layered .psd.
    That being said, I haven’t seen this problem in a while. Somewhere along the way it just started working like it’s supposed to.
