Activity › Forums › Apple Final Cut Pro Legacy › Importing .png files to FCP – help
  • Importing .png files to FCP – help
    Posted by Joey Williams on June 30, 2009 at 5:19 pm
    I have a DVD that I’m currently putting together. I have some images that I need to composite over the video in certain parts, and I’m having trouble with it. I created the images in Adobe Illustrator (CS4), and exported them as .png files. For some reason, when I try to import the .png files to FCP, it doesn’t take them. It will take .jpeg and .tiff, but not .png. I need the .png (or some equivalent) because .png files can export a transparent background that .jped and .tiff do not.
    Any ideas? Please help.
    JW
    TOAD ARRAY
    https://toadarray.com
    Arnie Schlissel replied 17 years, 3 months ago 3 Members · 3 Replies
  • David Roth weiss
    June 30, 2009 at 5:30 pm
    The problematic PNGs are mostly CYMK and need to be converted to RGB in Photoshop.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Joey Williams
    June 30, 2009 at 5:55 pm
    So true. Thank you very much.
    I must say I’m a little surprised there isn’t a way to head that off in Illustator… that would make things too easy I suppose.
    Thanks.
    JW
    TOAD ARRAY
  • Arnie Schlissel
    July 1, 2009 at 4:36 am
    [joey williams] “I need the .png (or some equivalent) because .png files can export a transparent background that .jped and .tiff do not.”
    .tiff does support transparency. I’m not sure if FCP sees it, though. The workaround is to use add an alpha channel to your .tiff to define the transparency for FCP.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
