Activity Forums Avid Media Composer Importing Photoshop elements
  • Importing Photoshop elements
    Posted by Tom John on January 2, 2006 at 1:12 am
    Hi, all,
    Whenever I create text in Photoshop which has a very soft drop shadow and import it into Avid Express or Adrenaline, it always has a fine white halo around the outer edge. I’ve tried changing the i/o and format settings on both programs, to no avail.
    Any suggestions?
    Thanx!
    Tom
    William909 replied 20 years, 8 months ago 4 Members · 4 Replies
  • Jon Zanone
    January 2, 2006 at 6:21 am
    Save your graphic as a .png. That should get you going…
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Oliver Peters
    January 2, 2006 at 12:56 pm
    Tom,
    The .png suggestion is good and I use it myself all the time, but the reason you are having a problem is that you must first merge the layer effects and rasterize the text in order for Avid to correctly recognize the transparency values. In Photoshop, create a blank layer above the layer with the text/shadow. Link the text layer with the blank layer and select “merge linked”. This will flatten/merge just that layer. If you have a multi-layered graphic, you can import this as a sequence, where the individual layers can be further manipulated with effects in Avid.
    Sincerely,
    Oliver
    Oliver Peters
    Post-Production & Interactive Media
    Orlando, FL
    http://www.oliverpeters.com
  • Tom John
    January 2, 2006 at 7:30 pm
    Thanks very much, guys! I will try this solution.
    Best,
    Tom
  • William909
    January 3, 2006 at 5:35 pm
    Another solution:
    Take the title layer with the drop shadow and merge it down with a blank layer. This will remove the little ‘f’ icon on the title layer but preserve the shadow. Then add a new layer below the title and fill it with black. Import it and you should have a nice black shadow…
