Activity Forums Adobe After Effects Importing paths from AE to Illustrator?
  • Importing paths from AE to Illustrator?
    Posted by Shirak Agresta on April 20, 2007 at 5:42 am
    Is this possible? I need to take a path created in AE and import it into illustrator so I can use it to make a vector object to bring BACK into AE. Convoluted, I know, but this is how it needs to be done right now. Illustrator won’t accept me copying from AE and pasting into it. How can I get around this?
    Thanks.
    P.S. Aaargh.
    Julius Caesar and the Roman Empire couldn’t conquer the blue sky.
    Van Huzendt replied 19 years, 4 months ago 3 Members · 4 Replies
  • Van Huzendt
    April 20, 2007 at 9:29 am
    Don’t know if this helps – in AE7 I drew a path (with the pen tool) and selected it, copied it (Ctrl-C) and pasted in directly into AI CS2 – it works! Is that what you’re asking?
    Cheers!
    Van
  • Shirak Agresta
    April 20, 2007 at 4:21 pm
    Yep! I’m using the same programs and it won’t work for me.
  • Richard Bachman
    April 20, 2007 at 7:42 pm
    I know this question has come up a lot in the past with prior versions of illustrator & AE, but there’s a preference setting variable in Illustrator for exporting – there are only 2 options so whichever one you’re using now, try the other and everything should cut/paste back and forth easily. Sorry I can’t be more specific at the moment…
  • Van Huzendt
    April 20, 2007 at 10:53 pm
    Hi Shirak,
    Try this – in Illustrator CS2 goto preference, under files and clipboard, Copy as PDF & AICB must be checked. Select the Preserve Paths radio button. I have mine setup this way – hope this works for you
    – Van
