Activity Forums Adobe Premiere Pro Importing P2 with spanned clips
  • Importing P2 with spanned clips
    Posted by Cody Walters on May 3, 2012 at 3:26 pm
    I ran across this the other day. I have a P2 clip that runs an hour long and is spanned across two cards and displays as two clips. I have both card contents copied to my drive. The first part of the spanned clip is fine, but the second clip that is on card two appears to be a duplicate of the first clip on card one. Is there a way in Premiere to connect these spanned clips similar to how Final Cut connects spanned clips?
    Cody Walters
    JW Studio LLC
    Houston Video Production
    Houston Wedding Videographer
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
    Cody Walters replied 14 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Alex Udell
    May 3, 2012 at 4:23 pm
    Hiya…
    If you use Ppro’s Media browser window, it understands P2 spanning….
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Cody Walters
    May 4, 2012 at 3:57 am
    Hi Alex,
    Yes, I did use the Media Browser to bring up the P2 folder. Am I able to select multiple cards (folders) at a time for it to understand the spanning?
    Cody Walters
    JW Studio LLC
    Final Cut Studio 3
    Panasonic HVX-200
    Canon 7D
  • Alex Udell
    May 4, 2012 at 4:20 am
    hmmm…..
    on your desktop…
    do both card folders have lastclip file?
    if not you might need to put all mxf’s into the one video folder of the set that contains lastclip….
    I know I have to do that in FCP sometimes.
    Alex Udell
  • Cody Walters
    May 5, 2012 at 7:42 pm
    No, not on the desk top. Yes, the folders have the full file structure strait from the P2 card (with last clip file). So I have two folders representing two cards on an external hard drive connected via firewire 800.
    Cody Walters
    JW Studio LLC
    Final Cut Studio 3
    Panasonic HVX-200
    Canon 7D
  • Alex Udell
    May 6, 2012 at 2:48 am
    If it’s two folders, each with Lastclip.txt, how is it spanned?
    Maybe I just don’t know enough….
    but I thought in a spanned set, there should be only 1 lastclip.txt
    you sure the camera was set to spanning and not segmenting clips on different cards?
    Alex
  • John-michael Seng-wheeler
    May 7, 2012 at 2:44 am
    Cody, If you just combine the contents folders into one everything will import properly.
    On windows, this is as simple as dropping one CONTENTS folder into the same folder that the other one is in.
    On Mac it’s a matter of coping all the video files into the other video folder and the same with the audio and clip and image folders.
    Then it’ll all import correctly.
  • Cody Walters
    May 8, 2012 at 2:14 pm
    Maybe I’m not explaining in enough detail or misunderstood spanning. I was shooting on a Panasonic HVX200. I think “segmented clips” more accurately describes what I have on my end. The last clip on card 1 and the first clip on card two, when put together, make up the entire clip. However, Premiere looks at the first clip on card 2 as the same clip as the last clip on card 1 and appears not to have the second part of the clip.
    Alex, I’m a little concerned about modifying the card structure. I was hoping there would be a more simple solution like selecting two folders in the media browser and Premiere would recognize the spanned clips and show all my P2 clips in the browser.
    Cody Walters
    JW Studio LLC
    Final Cut Studio 3
    Panasonic HVX-200
    Canon 7D
