Activity › Forums › Apple Final Cut Pro Legacy › Importing P2 spanned files
Posted by Christopher Shaun on October 5, 2008 at 10:18 pmHello,
I’ve FCP 5 on a Macbook Pro using an ext HD scratch disk.
Please could anyone tell me the steps I should take, or point me in the right direction to import a P2 spanned clip into FCP 5.
Thank you for your help.
Kylie Purcell replied 17 years ago 3 Members · 9 Replies -
Shane Ross
October 6, 2008 at 2:26 amI believe I answered this on the Apple forums, right?
Shane
Read my blog, Little Frog in High Def -
Christopher Shaun
October 6, 2008 at 2:37 amI’m not sure if this is the best way to handle this, but here’s a step by step method that worked for me:
COPY FOLDER
PASTE FOLDER AND RENAME IT
OPEN > MUST INCLUDE LASTCLIP.TXT > THEN > GO INTO CONTENTS :
AUDIO > xxx.MFX
CLIP > xxx.XML
PROXY >
VIDEO > xxx.MXF
VOICE >REPEAT PROCESS FOR EACH CLIP AND ENSURE IT HAS ITS OWN FOLDER W/ MATCHING LASTCLIP.TXT AND CONTENTS: AUDIO, CLIP, ICON, PROXY, VIDEO, VOICE
IN FCP
CLICK ON FILE>IMPORT>PANASONIC P2 AND IMPORT EACH FOLDER W/ INDIVIDUAL CLIP -
Shane Ross
October 6, 2008 at 3:49 amWhat? What are you doing? Sounds like you didn’t keep the original file structure intact. You GOTTA keep that original structure intact.
And if you want each clip in it’s own CONTENTS folder, then you should look into P2CMS…
Shane
Christopher Shaun
October 6, 2008 at 4:28 amActually, that’s exactly what I did – in every respect and it worked out just fine.
Shane Ross
October 6, 2008 at 4:36 amWhat is exactly what you did? use P2CMS?
Shane
Christopher Shaun
October 6, 2008 at 4:55 amHere’s what I did.
Copied the folder containing the spanned clip eg A
Pasted it in the same folder eg A copy
Renamed it eg B
Opened the folder
Opened CLIP > deleted all the files except the spanned file eg xxx.XML
AUDIO > deleted all the files except the spanned file eg xxx.MFX
PROXY >
VIDEO > deleted all the files except the spanned file eg xxx.MXF
VOICE >Then I imported the folder eg B into FCP
I repeated the above process with each clip that was in the folder renaming the folder eg C, D etc until I had a sep folder for each clip.
And this remedied the problem and I was able to import all the footage that I shot into FCP.
As an aside I’ll watch in future when shooting the camera and try to avoid shooting over 4G IGS a take. I’ve not ever experienced this before.
Kylie Purcell
September 15, 2009 at 11:19 amI don’t believe it…
Your idea worked! Ive tried everything, and this really random looking idea actually did it! I can’t believe it- thanks so much!!
Seriously I have been through all the posts so many times. Life saver!
