Activity › Forums › Avid Media Composer › Importing P2 Footage at an “m” resolution
Posted by Matthew Sakimoto on April 29, 2008 at 9:51 pmDoes anyone out there know if it’s possible to import P2 footage (copied to a drive) at any resolution other than 1:1 MXF. For instance, is there any way for me to import P2 footage at 4:1m and cut with it?
I’m assuming that if this is possible, it would have to be done on a Symphony Nitris, which is fine for me.
Any ideas, anyone?
Jon Zanone replied 18 years, 4 months ago 3 Members · 5 Replies -
Jon Zanone
April 30, 2008 at 11:45 amTranscode it from the P2 media to your storage at your desired resolution.
Jon
“So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
Del Amitri – “Make it Better” -
Matthew Sakimoto
April 30, 2008 at 11:01 pmOk, so that worked fine, but now I’m having trouble bringing up the media on others systems. I imported and transcoded on the software only version of Avid, but need to edit with it on Media Composers with bobs.
I consolidated the transcoded 4:1m media to our unity drives, but the bin containing the transcoded media will not open on the system we we want to use.
Any advice?
Jon Zanone
May 1, 2008 at 1:26 amAre you trying to go to a meridian system? If you are, it won’t work. Media is forward compatible, but not backwards, as I understand it. My geuss is you’ll have to export as QT and import into the meridian system.
Jon
Michael Hancock
May 1, 2008 at 2:06 am[Jon Zanone] “Are you trying to go to a meridian system? If you are, it won’t work. Media is forward compatible, but not backwards, as I understand it. My geuss is you’ll have to export as QT and import into the meridian system.”
Actually, media is backwards compatible if it fulfills certain requirements.
1) If you’re going to a Meridien system, OMF media only. MXF didn’t exist in the meridien days and it won’t work. If you have P2 footage, you have MXF footage and your Meridien won’t read it.
2) The resolution has to be an available resolution on the meridien system. Just like you can’t take 2:1 footage from a Media Composer to an Xpress Pro system, you can’t take a resolution that isn’t available on the Meridien and expect it to play. I have no idea if Meridien systems had “m” resolution, but if they don’t you’ll need to transcode to something else. If if your “m” resolution media is MXF, you need to figure out how to get it to OMF (if it possible to transcode from MXF to OMF? I honestly don’t know).
3) The capture codec has to be available on the Meridien system. For example, if you don’t have the DV option and you have DV footage, you can’t transfer the footage without transcoding to something else.
Otherwise, you can take OMF footage from Symphony and roll it back to an ancient Meridien if the resolutions and codecs are available on it.
Michael.
Jon Zanone
May 1, 2008 at 11:55 amThanks for clarifying, Michael!
Jon
