Activity › Forums › Avid Media Composer › Importing P2 files from network drive…
  • Importing P2 files from network drive…
    Posted by Jon Zanone on April 23, 2009 at 9:13 pm
    Avid MC 3.0.1ish…
    We’ve recently begun shooting P2, and dropping the contents of the cards into folders on a network drive (not Unity). When I tried to import the contents folder to bin, I get an error saying it could not mount the drive as a P2 card.
    Can I not import the contents folder from a network drive?
    Jon
    “Jamming our heads full of figures and angles
    And telling us stuff that we already know”
    Willie The Wandering Gypsy & Me
    Billy Joe Shaver
    Jon Zanone replied 17 years, 5 months ago 2 Members · 3 Replies
  • Michael Hancock
    April 23, 2009 at 9:46 pm
    Let me preface this by saying I have no idea if this will work and I’m going by memory here, but…
    Open your console and type “alldrives” without the quotes. Hit Enter, then try to import your P2 again. I think “alldrives” allows your Avid to see your network drives. Again, I’ve never done this and my memory may be fading but I thought I remembered hearing this works.
    Let me know if this works.
    Michael.
    I’ll be working late.
  • Jon Zanone
    April 23, 2009 at 10:49 pm
    Well you were more right than you thought. The ‘alldrives’ worked, but I got a different error:
    “The selected volume is a media drive but not a P2 media drive!”
    I like the exclamation point. It add finality to my ignorance.
    I tried dragging the ‘contents’ file structure into another folder on the network drive called “virtual” (that came from somewhere in the dark scary place) – no go.
    surely there must be a way to do this, no?
    Jon
    Billy Joe Shaver
  • Jon Zanone
    April 24, 2009 at 10:15 pm
    OK, I figured it out. Thanks Michael – and to the poster over at the Avid forum – both bits of information really helped! I’ve written instruction for this, based on our local workflow. Please use it as you wish!
    IMPORTING P2 MEDIA FROM A NETWORK DRIVE IN WINDOWS XP
    -Map the root folder as a network drive
    –Go to My Computer>Tools>Map Network Drive…
    –Select a drive letter (Windows will not let you select a letter that conflicts with an internal or network drive)
    –Select ‘Browse’ and navigate to the file location
    –Select the folder containing the P2 file structure
    –Deselect ‘Reconnect at Log on’ – the idea is to import the clips you need into your local media drives, not bog down the network by editing on it!
    -Hit ‘Finish’
    -Start Media Composer and select or create your project
    -Go to Tools>Console
    -Type in ‘alldrives’ (lower case, no spaces)
    –Hit ‘enter’ – you will see a message “All drives will be seen as media drives”
    –If you see the message “Only true Media drives will be seen as Media drives”, type ‘alldrives’ again.
    -Close the console
    -Import P2 clips as normal. The clips will not play normally – that because of the speed of the network.
    -Import the clips into your local media drives
    NOTE: After you have imported your clips, it is VERY IMPORTANT you tell the Avid not to use network drives – go to the console and type ‘alldrives’ again.
    Billy Joe Shaver
