Activity › Forums › Apple Final Cut Pro Legacy › importing older formats
  • importing older formats
    Posted by Rees Chapman on September 2, 2009 at 2:16 am
    Perhaps this question has been answered elsewhere; but I’m a musician and a photographer, rather ignorant of video technology. I apologize if this is redundant.
    My buddy has Final Cut Pro and a nicer HD videocamera; I’ve got access to some older 8mm VHS cameras. I want to videotape my band playing live, using the HD camera for the main camera angle, with the older cameras running simultaneously and focussed on individual musicians. I actually like the idea of the alternate camera clips being lower resolution, with black bars on the sides. Then, in editting, the vantage point switches back and forth between that of the main camera and those of the alternate cameras.
    I see where Final Cut Pro can access a great many different video formats, and I’m wondering: can we load the program with the HD video (and audio) signal alongside VHS video signals, syncronizing all of them, then edit by switching back and forth between them?
    Rees Chapman replied 17 years, 1 month ago 2 Members · 2 Replies
  • Nicole Haddock
    September 2, 2009 at 4:34 pm
    Well, theoretically, yes. There are a few things to be aware of.
    1) What you record needs to be all the same frame rate, and since you’ve got a VHS recorder, that would be 29.97. Make sure the HD camera records in this frame rate, or syncing stuff up is going to drive you nuts.
    2) FCP has a multi-camera functionality, where you can sync stuff up and then “call” it like in a television studio. However, FCP can only do this when the video is of the same codec and framerate, which yours will not be, so this won’t work. However, you can easily put your video streams on different tracks and cut between them the old fashioned way.
  • Rees Chapman
    September 2, 2009 at 7:28 pm
