Activity › Forums › Panasonic Cameras › Importing MXF into FCP
  • Importing MXF into FCP
    Posted by Gabrielle Dainard on June 1, 2009 at 12:51 am
    Hello, I am having problems importing MXF files into my FCP.
    I am running FCP 5.0, it has the p2 import option and the folder structure on the hard drive seems to be correct.
    every time i try to bring the files in i get this message:
    “one or more P2 clips failed to import; probable incomplete or corrupt clips”
    Should i be changing my setting in final cut? should i be converting the clips before i bring them in?
    if so what program can i get that will convert the MXF files into final cut friendly file?
    Thanks sooo much for any advice you can give me
    -gab
    Shane Ross replied 17 years, 4 months ago 4 Members · 3 Replies
