Activity Forums Adobe Premiere Pro Importing multiple stills above 5 second timeline default
  • Importing multiple stills above 5 second timeline default
    Posted by Zenbeer on February 15, 2007 at 4:28 pm
    I need to import hundreds of still images into my project at 10 seconds each, but Premeire Pro 2.0 is defaulted at 5 seconds per still image.
    I do not want to manually adjust each time in the project tab.
    Is there a way to change the default still image import setting to 10 seconds or higher? I cannot find a way to automate this process, and I reeeeeally do not want to manually adjust several hundred still images.
    zen
    Zenbeer replied 19 years, 7 months ago 2 Members · 2 Replies
  • Todd Terry
    February 15, 2007 at 4:36 pm
    Yes Zen…
    At least that is an easy fix (unlike the stills problem that I am wrestling with).
    In Premiere go to EDIT > PREFERENCES > GENERAL and on the pop-up page change the “Still Image Default Duration” from 150 to 300 frames… then any new still will import as 10 seconds instead of the default 5 seconds.
    Todd
  • Zenbeer
    February 15, 2007 at 4:40 pm
    Ahhh there it is! Dang, I was staring right at that too. 🙂 Thanks man. -zen
