Activity Forums Adobe Premiere Pro Importing multiple sequences
  • Importing multiple sequences
    Posted by Joe Kilburn on April 25, 2013 at 2:32 am
    Hello,
    I have several different, fairly complex sequences from many different projects that I want to render together into one video file. The problem I’m having is the more sequences I import, the more Premiere locks up and eventually becomes unresponsive. Would it help if I first pre rendered each individual sequence before importing to the main Premiere project?
    I’m starting to think I’m not going about this the right way…
    I suppose a workaround would be to export each individual sequence first, then import each one into a new Premiere project and render them together that way. The only problem with this is that I’m putting the videos through double compression.
    I’m sure there’s a solid method of accomplishing this task that is just beyond my range of knowledge.
    Thanks in advance.
    Walter Biscardi replied 13 years, 5 months ago 2 Members · 11 Replies
  • 11 Replies
