Activity Forums VEGAS Pro importing multiple EX files
  • importing multiple EX files
    Posted by Charles Martin on August 21, 2010 at 3:53 pm
    Trying to import multiple EX files to Vegas Pro 9d. All the files are in a folder on my hardrive. If i select ‘import’ and steer to the folder with the files i get all the bpav files….i can select those bpav files as a group but it will only allow me to import one at a time…. i know you can use device explorer to import the files from the SxS card…but i don’t work that way …for a number of reasons…. Is there no way to batch import EX files when they are on your internal…or an external hardrive?
    Charles Martin replied 16 years, 1 month ago 1 Member · 1 Reply
  • Charles Martin
    August 23, 2010 at 10:30 am
    Solved…. ! you right click in Device Explorer….even though its blank…. and click ‘browse’ …go to the folder you want and the EX files will apppear…..then just batch import whatever you select..
