Importing MTS to Final Cut 7 problem
Final Cut Pro 7 is not recognizing the MTS files on my SD card. I think I might have inadvertently moved the files around? or somehow the files got corrupted?
My SD card is currently plugged into the computer. When I open Log & Transfer, nothing appears. When I drag the Private folder from the SD card file into the Log & Transfer window, I get the message:
“Private contains unsupported media or has an invalid directory structure.”
So looking in the directory structure in the SD card, I think the issue is that the file called CLIPINF starts at 00000.CPI and goes to 00322.CPI, while the file called PLAYLIST starts at 00000.MPL and goes to 00051.MPL, and the file called 000245.MTS and goes to 00322.MTS. Basically, I think the SD card is totally messed up. Am I right? Is there any way to fix this?
I’ve only been able to work around this by converting the files into Pro Res through Compressor, but this takes an hour for a 5 minute clip. Is there any other way to use the files in this card? Or am I doomed to spend the several days of my life converting files?
Also terribly annoying that Mavericks (at least I think it’s Mavericks) now reads all the AVCHD files as one quicktime item and I keep having to unpackage them.
Thanks in advance for any ideas as to what to do about these files!
