Activity › Forums › Apple Final Cut Pro Legacy › importing mpegs to Final Cut Studio
  • importing mpegs to Final Cut Studio
    Posted by Veronica Santos on July 7, 2011 at 4:35 pm
    Hello everyone,
    I have the following situation and I need some help.
    I captured HDV material with Adobe Premiere in a PC. The files I got are .mpeg.
    Then I tried to import them with Final Cut Studio 3 so I could work with them there, but it doesn´t seem to work.
    When I try to do this, the program just doesn´t react anymore (the coloured ball spins and spins)…
    So, I don´t know if the problem is that FC just can´t read .mpeg files or, if the files are too big (aprox.6 gigas each, it is HDV), or I don´t know really…
    If somebody knows how to help me, I would be very thankful! 🙂
    (I wouldn´t like to capture this material all over again…) thanks!
    Veronica Santos replied 15 years, 2 months ago 2 Members · 4 Replies
  • Shane Ross
    July 7, 2011 at 5:26 pm
    Use Compressor to convert to ProRes. Then import into FCP
    Shane
  • Veronica Santos
    July 7, 2011 at 7:03 pm
    Thank you very much!!!
    With your advice I solved my problem! 🙂
  • Veronica Santos
    July 8, 2011 at 12:44 pm
    Hello Dave,
    Thank you very much for your suggestion.
    I have thou another coupple of questions.
    I already have the MPEG Streamclip software.
    My situation is that I have two tipes of footage. I have DV 960×540 footage and HDV 1440×1080 footage.
    I have to edit a documentary with this footage and I thought that the best way was to convert the HDV footage into DV footage (reduce the format). My question is: Which would be the best way to do it?
    My other question is: If the best codec to work is the ProRes 422 how do I choose this option in MPEG Streamclip? I tryed and I didn´t find any option like this.
    Thank you very much.
    Cheers
  • Veronica Santos
    July 8, 2011 at 12:52 pm
    Hi again Dave,
    I also forgot to ask. When I finisch my edition, which is the best format to export the movie?
    This is not for Televsion specifically. This is a project for the university and that is why it should be a format that could be read by MAC and by PC, with the best resolution and lowest “weight”.
    And which format wpuld be the best one to make a Trailer of the movie and load it on the internet with the same criteria (high resolution, low weight)
    Cheers,
    Veronica
