Activity › Forums › Apple Final Cut Pro Legacy › Importing MPEG files
Posted by Brad Jones on December 23, 2009 at 8:15 pmWhen I import an MPEG file, the video imports ok, however the audio does not import with it. Is there a setting that I’m missing, or some other way to correct this issue?
J. Brad Jones
BBB Communications
http://www.bbbtv12.com
http://www.wyshtv.comShamol Majumder replied 16 years, 8 months ago 4 Members · 7 Replies -
Shane Ross
December 23, 2009 at 8:20 pmFCP doesn’t like MPEG files…doesn’t edit them. Get MPEG STREAMCLIP from square5.com and convert them to DV/NTSC files (NOT .DV files!), or ProRes if they are HD MPEGS…
Import the resulting files into FCP.
Shane
Read my blog, Little Frog in High Def -
David Roth weiss
December 23, 2009 at 8:25 pm[Brad Jones] “When I import an MPEG file, the video imports ok, however the audio does not import with it. Is there a setting that I’m missing, or some other way to correct this issue?
“FCP does not import “muxed” audio, which is the way audio is handled in MPEG compression.
Get yourself the MPEG Streamclip app (free downloads are available all over the Web) and use it to export the MPEG as an editable Quicktime, preferably that matches other video you are editing.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
David Roth weiss
December 23, 2009 at 8:26 pmShane,
You beat me to the punch… You’re obviously drinking too much coffee again…
Have a great holiday!!!
David
David Roth Weiss
Brad Jones
December 23, 2009 at 8:27 pmOK! Makes sense. It plays the video but no audio. Just converted to Pro Res and that took care of the problem.
J. Brad Jones
BBB Communications
http://www.wyshtv.com -
Brad Jones
December 23, 2009 at 8:30 pmThanks guys! I’m searching now!
Merry Christmas!
J. Brad Jones
BBB Communications
Shane Ross
December 23, 2009 at 8:31 pmCall me Quick Draw McShane!
This is what I do when I render….
Shane
Shamol Majumder
January 7, 2010 at 8:50 amThere is no need to re-encode the video, just demux with Streamclip using the option “Demux to Unscaled M2V and AIFF…”, that’s made for FCP. You will only have to render in the timeline what you use, not the complete video.
MPEG Streamclip User’s Guide:
demuxes the stream and creates an “unscaled” M2V video file and an AIFF audio file; you can import these two files in Final Cut Pro 4 or HD (and also in Final Cut Express if you have the MPEG-2 component); usual rendering time is required. Please DO NOT use drag & drop to import the files (Final Cut may crash due to an internal bug), but open the M2V file using the File menu and the AIFF file will be automatically linked (if you used the same name for the two files).
The “unscaled” M2V file is a demuxed file which tells QuickTime and Final Cut to not prescale it, e.g. to 720 x 540; it preserves its original size e.g. 720 x 576 or 720 x 480 so you won’t lose quality when you render it. This is a special feature of MPEG Streamclip.Shamol Majumder
Editor/Colorist
Twitter
