Activity › Forums › Adobe After Effects › importing .mov = crash??
  • importing .mov = crash??
    Posted by Aaron Bear on March 23, 2010 at 9:04 pm
    Hey all,
    Ive run into this problem that I cant seem to get around. When I try to import a .mov (png or jpeg encoding, ~250 mb) into my project bin, After Effects stop responding and crashes.
    The only way Ive been able to import my clip is to convert the .mov clip to a .mov with h.264 or mpeg-4 encoding. Although this works, its compressed and a lot of the color information is lost.
    Any ideas?
    Thanks in advance!
    -Aaron-
    “Wherever you go, there you are”
    Joey Foreman replied 16 years, 6 months ago 2 Members · 3 Replies
  • Aaron Bear
    March 23, 2010 at 9:57 pm
    Thanks for the quick response. Everything was set to the defaults, I dont usually mess with a lot of the settings. I double checked and multiprocessing was turned off. I tried turning it on and get the same results. Open GL is not enabled. Im running 64 bit with 8 gb of ram so I should be able to handle the clips with ease. Im currently running CS3.
    It seems to be importing the clips that crashes AE.
    -Aaron-
  • Aaron Bear
    March 23, 2010 at 10:08 pm
    I did find a work around. I exported the clip as a png image sequence and it imported just fine into AE. It might be a bit of a pain and an extra set, but at least it works.
    Thanks again.
    -Aaron-
  • Joey Foreman
    March 24, 2010 at 5:16 am
    You don’t ever want to do that. In fact, that’s the exact opposite of what you should do.
    I hope Dave doesn’t mind my referring you Dave’s Stock Answer #1 in his own thread.
    Dave’s Stock Answer #1:
    If the footage you imported into AE is any kind of the following — footage in an HDV acquisition codec, MPEG1, MPEG2, AVCHD, mp4, m2t, H.261 or H.264 — you need to convert it to a different codec.
    These kinds of footage use temporal, or interframe compression. They have keyframes at regular intervals, containing complete frame information. However, the frames in between do NOT have complete information. Interframe codecs toss out duplicated information.
    In order to maintain peak rendering efficiency, AE needs complete information for each and every frame. But because these kinds of footage contain only partial information, AE freaks out, resulting in a wide variety of problems.
    Dave LaRonde
    Sr. Promotion Producer
    The .png thing is fine, great. You could go tiff too.
    I’m a fan of the tiff.
