importing more mpg clips with media import
With Sony Vegas 0.0b, clips saved from Sony HDD camera on computer disk, these clips are in mpg format.
I am trying to import more than 700 mpg clips with media import, because I need to see all of them, as I need to trim from each clip some part. The overall size of clips is 25 GB.
If I import it at once, it takes more than two hours and never finishes, it finishes with message “some clips have errors, do you want to select different, or ignore one, or ignore all…”. Whatever I select, ends with crash.
If I import clips in lets say 10-20pcs, it looks nice, but after getting one half of clips, it finishes as before. I try also to save the project, but then after the crash, it cannot load the saved project, without reason, just cannot.
Is there some limitation of number or size of imported clips?
For explanation, I have enough disk space, more than 100GB, my PC has 4GB RAM, it is a quad core machine…
I tried also to convert mpg to DV, but I cannot do this, because those 25 GB would be nearly one TB.
Thank you for helping me on solution with this problem.Martin
