Activity Forums Adobe After Effects Importing Mocha tracking data into CS6
  • Importing Mocha tracking data into CS6
    Posted by Jimi Lund on August 13, 2012 at 9:17 pm
    Hi all,
    I’m successfully tracking an object (A computer monitor with motion, scale, rotation, shear and perspective all required) and then copying the tracking data to paste onto a text layer made in Illustrator. I’m trying to comp the text onto the monitor.
    When I paste the data however, the text just “disappears”, as though the opacity has been turned to 0%.
    I’m flummoxed as to why this is happening. Am I missing something basic?
    Any help would brilliant.
    Jimi Lund replied 14 years, 1 month ago 4 Members · 5 Replies
  • Tudor “ted” jelescu
    August 13, 2012 at 10:25 pm
    Parent text layer to a Null, apply track data to Null, use the Position controls in the text layer to re-position. Most likely your text layer is outside the visible area of your comp.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • John Kaley
    August 14, 2012 at 12:55 am
    Pre-comp your Illustrator file into a compostion that is the exact resolution and frame rate as the tracked shot. Apply your tracking/corner pin data to this layer.
  • Roland R. kahlenberg
    August 14, 2012 at 9:46 am
    I’m with John on this one cos if you’ve tracked perspectives then there is a good chance that you’ll want corner-pin tracking data. And when applying corner-pin tracking data, you do not want to apply it to a Null but rather to the insert-layer.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
    August 14, 2012 at 12:03 pm
    My bad, I read again the post and I agree with John and Roland.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Jimi Lund
    August 14, 2012 at 12:10 pm
    Thanks guys,
    I’ll try those suggestions shortly and let you know how it turns out.
