Activity › Forums › Apple Final Cut Pro › Importing MiniDV tapes
Posted by James Taylor on July 27, 2011 at 7:23 pmI have a few MiniDV tapes I want to import into FCPX. I just did the first one and everything seemed to go OK. However, I had closed FCPX and tried to open the file in Quicktime Player, but there was not sound? There was definitely sound in FCPX when I scrub through the clip. Is this normal behavior or have I done something wrong?
JT
Fred Waycoot replied 15 years, 1 month ago 4 Members · 17 Replies -
Tom Wolsky
July 27, 2011 at 8:44 pm“I just did the first one”
How did you do the first one exactly? Did you use FCP?
Open the clip in the QT player and report exactly what it says in the movie inspector.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Coming in 2011 “Complete Training for FCPX”
and “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press -
James Taylor
July 27, 2011 at 10:09 pmThanks Tom,
Yes, I used FCPX to capture it. I didn’t check any of the boxes (proxy files or separate silent channels).
QTime says:
/Users/Taylor/Movies/Final Cut Events/New Event 7-27-11/Original Media/2004-03-23 08_50_31 (id).mov
DV, 720 x 480 (640 x 480), Millions
16-bit Integer (Little Endian), 4.0 (_ _ _ _), 32.000 kHz29.97
38.6 MB
30.82 Mbit/s
640 x 480 pixels (Actual)
JT
Tom Wolsky
July 27, 2011 at 10:29 pmThat all looks fine. I don’t understand why there’s no audio in the QT player.
All the best,
Tom
Craig Seeman
July 27, 2011 at 10:35 pmI can’t help but think the 32kHz audio has something to do with it . . . but maybe not.
Open the file in VLC and go to Audio/Visualizations and select Spectrum and tell me if you see the bar graphs moving. -
James Taylor
July 28, 2011 at 2:10 amOK, this is very weird. I randomly pulled several clips to the desktop (copied from the FCPX events folder). Two of the five clips opened in VLC and had sound, the others opened, but did not have sound. Garage Band would import them, but with no sound. iMovie tried to import (copied them to the iMove folder), but would not show them in the project. Still wondering why FCPX will play audio just fine, but no other program will play the audio?
JT
JT
James Taylor
July 28, 2011 at 2:19 amI just opened one of the clips that would not play in VLC or QTime into AECS5 and the sound works fine.
JT
Craig Seeman
July 28, 2011 at 2:45 amCheck the clips in MediaInfo and see if there’s any pattern regarding the audio between clips that do and don’t play in Quicktime.
Did you see the spectrum meters move on the clips that didn’t seem to have audio?
Seeing and hearing may be different so please do confirm. -
James Taylor
July 28, 2011 at 3:07 amAll of the clips play in Quicktime – none of them have audio.
In VLC, the clips with sound showed the spectrum meters. The clips with no sound in VLC did not show the spectrum meters.
All the clips play fine in FCPX.
JT
Craig Seeman
July 28, 2011 at 11:25 amPlease check clips in MediaInfo and see what it says for the audio.
https://mediainfo.sourceforge.net/en/Download -
James Taylor
July 28, 2011 at 3:01 pmHere is what it says:
General
Complete name : /Users/Taylor/Desktop/2004-04-03 17_02_28 (id).mov
Format : MPEG-4
Format_Commercial_IfAny : DVCPRO
Format profile : QuickTime
Codec ID : qt
File size : 7.78 MiB
Duration : 2s 69ms
Overall bit rate : 31.5 Mbps
Encoded date : UTC 2011-07-27 21:34:29
Tagged date : UTC 2011-07-27 21:34:31
Writing library : Apple QuickTime
com.apple.proapps.manufacturer : Canon
com.apple.proapps.modelname : ELURA50
com.apple.proapps.clipID : 52F7521B-DD09-4453-B85B-E9AD0A21C16C
com.apple.proapps.ingestDate.des : 2011-07-27 14:34:29 -0700
com.apple.proapps.originalFormat : DV/DVCPRO – NTSC
com.apple.proapps.mediaRate : Unknown kind of value!
com.apple.proapps.timecodeFormat : Drop
com.apple.quicktime.creationdate : 2004-04-03T17:02:28-0800
com.apple.quicktime.make : Apple
com.apple.quicktime.model : MacBookPro8,2
com.apple.quicktime.software : Mac OS X 10.6.8 (10K549)Video
Format : DV
Codec ID : dvc
Duration : 2s 69ms
Bit rate mode : Constant
Bit rate : 24.4 Mbps
Width : 704 pixels
Original width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:1:1
Bit depth : 8 bits
Scan type : Interlaced
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.411
Stream size : 7.10 MiB (91%)
Title : Core Media Video
Encoding settings : wb mode= / white balance= / fcm=auto focus
Material_Duration : 2102
Material_StreamSize : 7560000
Material_FrameCount : 63Audio #1
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Unsigned
Codec ID : lpcm
Duration : 2s 69ms
Bit rate : 2 048 Kbps
Channel(s) : 4 channels
Sampling rate : 32.0 KHz
Bit depth : 16 bits
Stream size : 517 KiB (6%)
Title : Core Media Audio
Material_Duration : 2135
Material_StreamSize : 546680Audio #2
Format : PCM
Muxing mode : DV
Muxing mode, more info : Muxed in Video #1
Duration : 2s 69ms
Bit rate : 768 Kbps
Channel(s) : 2 channels
Bit depth : 12 bits
Delay relative to video : 133ms
Stream size : 0.00 Byte (0%)Audio #3
Format : PCM
Muxing mode : DV
Duration : 2s 69ms
Bit rate : 768 Kbps
Bit depth : 12 bits
Stream size : 0.00 Byte (0%)Menu
Title : Core Media Time Code
Bit rate mode : CBRJT
