Activity Forums Media 100 Importing Media100 SW Beta Project Timeline into After Effects.
  • Importing Media100 SW Beta Project Timeline into After Effects.
    Posted by Arnold Foote on December 11, 2005 at 4:58 am
    Dear All,
    I am trying to import my Media100 SW Timeline into After Effects as I have done countless times using 8i. What is interesting is that it creates an XML file. What is this and why is it there. It hangs my machine every time I try to import it into AE.
    Should I give up on this and re-edit it on Final Cut? I need to finish this project on Monday. All advice will be much appreciated.
    Cheers,
    JJ
    jj.foote@mac.com
    Arnold Foote replied 20 years, 9 months ago 2 Members · 4 Replies
  • Floh Peters
    December 11, 2005 at 10:16 am
    [admarkjamaica] “I am trying to import my Media100 SW Timeline into After Effects as I have done countless times using 8i. What is interesting is that it creates an XML file. What is this and why is it there.”
    Media 100 uses XML as a exchange format with AfterEffects. It
  • Arnold Foote
    December 11, 2005 at 5:52 pm
    Do I still export in the same way?
    jj.foote@mac.com
  • Floh Peters
    December 11, 2005 at 5:57 pm
    [admarkjamaica] “Do I still export in the same way?”
    You export using the File->Export->Export to AfterEffects command. You need to place the “Media 100 Project XML Importer” into the AfterEffects->PlugIns->Standard->Format->fpf folder.
  • Arnold Foote
    December 11, 2005 at 6:31 pm
    Thanks… I will try it first thing tomorrow morning
    jj.foote@mac.com
