Activity Forums VEGAS Pro importing media video failures.
  • importing media video failures.
    Posted by Useph George on June 28, 2010 at 7:39 pm
    Is there a way to get vegas pro 9e to inform you as to why it is refusing to decode the video stream?
    i would like to inverse telecine an FP24 video file created by a canon vixia hfs100 camcorder.
    It seems like that, from initial testing, that MENCODER can remove the 2:3 coding without shifting the encoded cadence.
    But when I try to recreate the video file, vegas appears to reject the video. Am I missing something important to recreating the AVCHD/h264 file that can be read by vegas pro?
    win 7/ media player appears somewhat capable at playing this file.
    [gat@MyLaptop mplayer]$ mediainfo a.avi
    General
    Complete name : a.avi
    Format : AVI
    Format/Info : Audio Video Interleave
    File size : 31.5 MiB
    Duration : 11s 8ms
    Overall bit rate : 24.0 Mbps
    Writing application : MEncoder SVN-r31525-4.4.2
    Writing library : MPlayer
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : h264
    Duration : 10s 802ms
    Bit rate : 24.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.483
    Stream size : 31.2 MiB (99%)
    Writing library : x264 core 98 r1643 0cd5d69
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=24000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Mode extension : CM (complete main)
    Codec ID : 2000
    Duration : 11s 8ms
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Video delay : 83ms
    Stream size : 344 KiB (1%)
    Alignment : Split accross interleaves
    Interleave, duration : 470 ms (11.26 video frames)
    Interleave, preload duration : 500 ms
    John Rofrano replied 16 years, 2 months ago 2 Members · 1 Reply
  • John Rofrano
    June 28, 2010 at 9:05 pm
    Vegas Pro expects AVCHD to be in an MPEG2 Transport Stream (MTS) wrapper. It is not expecting it in an AVI file and my guess is that the AVI decoder doesn’t know what to do with it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
