Activity Forums Adobe After Effects importing maya camera data in AE, problems
  • importing maya camera data in AE, problems
    Posted by Anonymous on June 10, 2005 at 12:00 am
    I searched the forum for this and I found the same question but no answer so I just copied the question:
    ” Hey guys,
    I’m having some issues with bringing a scene from Maya into AE. I’ve done it before, but somehow things have changed now. And I’m not sure how to change it back! Okay, here is the problem…
    I’ve got a scene in Maya 6.5 Unlimited. It contains a camera and a bunch of null objects (named appropriately). I set the camera’s resolution to 720×480 in Render Globals. I bake the camera’s keyframes. I save it as a Maya ASCII file (.MA). Then I bring it into AE 6.5 Pro. This is where the confusion begins. It brings everything in just fine… nulls and camera alike. But the comp is 320×240 in size! And resizing a 3D comp in AE is just not an option for matching up the 3D data to a rendered video file. The thing I noticed is that if I go to the “Import” dialog in AE 6.5, and I highlight the Maya file to bring it into AE, it says “Import as: Composition – Cropped Layers” instead of just import as composition. But I’m not sure how to change this. Cropped Layers is the only option available there. Anyone know what I need to do to remedy this? Please??”
    -Robert Morris
    Ron Lindeboom replied 21 years, 3 months ago 2 Members · 1 Reply
  • Ron Lindeboom
    June 10, 2005 at 3:58 pm
    You might want to ask this question in the Maya forum here at the Cow as Maya is so deep that those who use it alot tend to think of themselves as Maya users who use After Effects, and not the other way around — so, you are more likely to get your answer there.
    Best regards,
    Ron Lindeboom
    creativecow.net
