Activity Forums Avid Media Composer Importing Markers onto AVID Clips
  • Importing Markers onto AVID Clips
    Posted by Ryan Drum on May 30, 2017 at 2:29 pm
    Hi guys,
    I have a question about markers and the way avid reads them. Is there a way of formatting a text file so that I can import the information as markers on a clip? I have a video hosting site that assigns a timecode to every comment in the comments section, and I am looking for a quick and easy way to assign these comments to markers in AVID.
    Any insight would be very appreciated! Thanks!
    Ludmil Kazakov replied 9 years, 3 months ago 4 Members · 5 Replies
  • Bouke Vahl
    May 30, 2017 at 2:34 pm
    Sure, it’s easy.
    Export a marker list as .txt and study the file. It’s not that hard.
    Bouke
    http://www.videotoolshed.com
  • Ryan Drum
    May 30, 2017 at 3:54 pm
    I’ve got the importing markers working well on the record monitor – but I would like the assigning of markers to be to the clip, not necessarily a sequence. When I try to put the .txt file on the specific clip it says “the record monitor must be selected.”
  • Michael Phillips
    May 30, 2017 at 8:08 pm
    There is no ability to import markers on source clips via a text file (ALE). It can be done via an AAF.
    Michael
  • Bouke Vahl
    May 31, 2017 at 1:52 pm
    Sure you can, with a few extra steps.
    Autosequence the clips you want the markers on, import markers on that sequence, copy/paste markers into the source.
    (I assume the markers have to be set on V1.)
    Instead of autosequence, any sequence with start / end overlapping the source will do.
    hth,
    Bouke
  • Ludmil Kazakov
    June 2, 2017 at 6:32 pm
    I am having the same issue.. markers are currently on the timeline.. so when i frame match there are no markers.. and i need them on the source clip.. how do i do that? i tried export XML but when I have the clip opened and I am in the markers window, i cant import markers “The Record monitor must be selected”
