Activity Forums Adobe After Effects importing map with 170 layers into ae and vectorize?
  • importing map with 170 layers into ae and vectorize?
    Posted by Constanti Dinu on March 5, 2015 at 9:09 am
    hi!
    i have a huge psd geographical world map (21 600 x 10 800) with 170 layers. each country is a layer on its own. I want to import this map into AE and to get each country layer as a solid or shape, so it could be a vector. Ideally each layer to be cropped on his own dimension (you know, like when you import a psd into after as a retain layer size comp).
    i haven’t found a way to achieve this so i’m asking you guys for ideas. Also, do you think will turn out to be a faster reder then importing the map into AE as it is (raster layers)?
    Tudor “ted” jelescu replied 11 years, 5 months ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    March 6, 2015 at 8:19 pm
    You can use the auto trace feature in Illustrator to vectorize the layers, however that still takes some work. I would suggest alternative options – there is a great plugin that works with map data directly in AE and it’s only 99 bucks:
    https://aescripts.com/geolayers/
    Tudor “Ted” Jelescu
    Senior VFX Artist
