Activity Forums Adobe Encore DVD Importing m2v
  • Importing m2v
    Posted by Don Holland on September 7, 2007 at 6:57 am
    Greetings,
    The Encore manual states you can import m2v files, but it seems as Encore wants to re-transcode them. Is there a way to stop that from happening? Imported ac3 files don’t get re-transcoded.
    Don
    Don Holland replied 19 years ago 4 Members · 9 Replies
  • 9 Replies
  • Jeff Bellune
    September 7, 2007 at 10:25 am
    How was the .m2v file encoded? What software was used and what were the encoding settings?
    -Jeff
  • Don Holland
    September 7, 2007 at 11:56 am
    The files are encoded in Comprssor. Here are the information from th codec:
    Name: HD MPEG-2 19.0Mbps
    Description: For HD DVD. Fits up to 30 minutes on a DVD-5
    File Extension: m2v
    Estimated file size: 7.91 GB/hour of source
    Type: MPEG-2 video elementary stream
    Usage:HD DVD
    Video Encoder
    Format: M2V
    Width and Height: Automatic
    Pixel aspect ratio: Default
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Frame Controls: Automatically selected: Off
    Start timecode from source
    Aspect ratio: Automatic
    Selected 16:9
    Field dominance: Automatic
    Average data rate: 18 (Mbps)
    2 Pass VBR enabled
    Maximum data rate: 27 (Mbps)
    High quality
    Best motion estimation
    Closed GOP Size: 1/2 second, Structure: IBBP
    DVD Studio Pro meta-data enabled
  • Jeff Bellune
    September 7, 2007 at 12:00 pm
    Encore doesn’t support HD-DVD encoding – it accepts SD DVD compliant files and Blu-Ray disc compliant files.
    For HD-DVD you will need DVDSP.
    -Jeff
  • Don Holland
    September 7, 2007 at 12:42 pm
    That explains that! Thanks Jeff.
  • Joe Bowden
    September 7, 2007 at 5:47 pm
    HD DVD encoded to MPEG-2 should be usable in Encore without re-transcoding – IF you build to Blu-ray. However, if you try to build a DVD, it will get re-transcoded to be MPEG-2 legal for DVD.
  • George Wing
    September 8, 2007 at 10:47 am
    [Jeff Bellune] “For HD-DVD you will need DVDSP.”
    You can also go with Ulead’s DVD MovieFactory 6 Plus. Pretty good value for “basic’ HD-DVD Authoring (imho), and it also includes Blu-ray burning (direct from video source).
    Regards,
    George
  • Jeff Bellune
    September 8, 2007 at 11:14 am
    If he used Compressor, and DVDSP metadata was enabled, then I’m 99.9% sure he’s on a Mac. Does Ulead have Mac versions of their software?
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • George Wing
    September 8, 2007 at 12:07 pm
    [Jeff Bellune] “If he used Compressor, and DVDSP metadata was enabled, then I’m 99.9% sure he’s on a Mac. Does Ulead have Mac versions of their software?
    -Jeff”
    Nope, I don’t believe Ulead has Mac versions of their software. But today, alot more folks have both platforms and/or a Mac running Windows software.
    Regards,
    George
  • Don Holland
    September 10, 2007 at 10:10 pm
    I already own DVDSP and Encore. I am not buying any more software. I am tring to make a Blu-Ray disc. Should I compress my footage with H.264 ratheer than m2v?
