Importing M100 mov file into Final Cut
We have just (last week) moved from Media100 to Final Cut Pro 5 on a G5, and burned the Media100 hardware and software as we danced around the bonfire.
For my current project, I’ve captured Sony XD-Cam footage as 10-bit uncompressed, and am editing in a 10-bit uncompressed sequence. All good. I need to incorporate several minutes of an existing program that we cut on the Media100i 8.2 and saved as a self-contained mov file. It was originally captured and edited in Media100 as 640-480 square pixels.
With the Media100 transcoder installed, I opened the M100 file in Quicktime, and exported it as a 10-bit uncompressed quicktime movie. I’ve tried several settings, but I am still having problems when I bring the clip into FCP:
— it requires rendering. Is that normal? Why would it have to render if it is a 10-bit uncompressed mov in a 10-bit uncompressed sequence?
— there are some graphics in it (moving boxes) that look horrendous now. Jerky, field/frame flicker, etc. The video itself looks fine, even where there is movement.
— what is the best export setting in QT to resize and deal with the dimension and pixel difference? The imported file must visually match the newly captured footage — no letterboxing. If I have to, I could accept an aspect ratio stretch. But ideally, it should match. Should I do the resize in the export or leave it alone and resize in FCP with the motion tab?
— is there a problem with importing a mov file that has different settings or pixel size than the sequence? (i.e., 8-bit uncompressed, animation, square pixles vs CCIRxx, etc.)
I’m trying many tests but would appreciate info from anyone else who has done this. I am also doing it with much trepidation because I experienced some terrible crashes doing this the first time, and even touching the mov clip to try to delete it from the sequence caused more crashes… corrupted project that could not be saved with an XML export/import… or any other method.. had to revert to previous days’ autosave. I think it was coincidence, unrelated other problems, and have since done a total erase/reinstall of everything. But importing these makes me nervous, like a dog approaching an electric fence wire…
Scratch
