Activity Forums Maxon Cinema 4D Importing logos into C4D
  • Importing logos into C4D
    Posted by Jessica Whelan on February 15, 2011 at 3:52 pm
    New at this Cinema 4D thing, is there an easy way to import logos from photoshop into Cinema 4D? I’ve tried to use Illustrator but it doesn’t work…. Help!!!
    Andrew Wilson replied 15 years, 6 months ago 3 Members · 2 Replies
  • Scott Benson
    February 15, 2011 at 4:05 pm
    Illustrator does work, but you have to save your file as version 8 or prior. You can then either open it directly into C4D using File->Open, or in the Objects pane, choose File->Merge Objects and it will bring the paths into your current scene.
  • Andrew Wilson
    February 16, 2011 at 12:26 pm
    …and in order to extrude a logo from ai with multiple paths, make your imported ai path a child of an extrude nurbs object and make sure ‘hierarchal’ is checked in the extrude nurbs property window.
    Andrew Wilson
    WestView Digital Video & Design
    http://www.westviewdigital.com
