Activity Forums Apple Final Cut Pro Legacy Importing Logic Bounces to FCP 4.5
  • Importing Logic Bounces to FCP 4.5
    Posted by Beelaster on November 6, 2005 at 7:04 pm
    Cowsters-
    A question. I am cutting a live show right now. I have sound sources direct from the board, a stereo room mike setup, and 3 cameras. Which adds up to 4 stereo pairs and one mono signal. I am making the board mix the tonal center and mixing frequencies based on it. I have mastered the board and the stereo room in Logic @ 24-bit resolution (down from Nuendo 32-bit). It sounds wicked. There is shimmer and air and everyone is articulated.
    The problem is- when I import the bounces to FCP, the sound quality goes down the tubes. The tracks are clipped, there is no air, the highs darken..it’s like everything was compressed with high gain.
    So I ask, humbly, whether there are any setttings I’ve missed- aside from the gain and pan, I assume that the bounces enter FCP unmodified. Do other people notice a lack of “tranparency” in their bounces? I have experimented with importing tracks that were bounced at really low levels, and the sound is just as clipped, but at a lower gain (if that makes sense).
    As far as I know, hardware is not an issue because the signal, once inside my rig, stays digital.
    It would make me so happy to resolve this. Thanks in advance to all of you experienced persons.
    Bee
    G5 dual 2.0/5.5gig/sonnet allegro FW800 PCI/3X250 LaCie FW800 extreme/AJA Io/Horita BSG-50/DSR-45/DSR-11/M-Audio Delta 1010LT/JVC Hi-Res Ref Monitor/stock Radeon video card/Prod Suite/Logic 7.1
    Beelaster replied 20 years, 10 months ago 2 Members · 2 Replies
  • Chris Wyatt
    November 7, 2005 at 6:22 am
    Hi Bee
    just a thought – is your FCP sequence audio set to 24 bit or 16 bit?
    If it is set to 16 bit i think what you are describibng would be the result.
    Best Regards
    Footagehead
  • Beelaster
    November 7, 2005 at 5:08 pm
    Hello footagehead-
    The sample rate in the FCP browser is set at 32-bit floating point and the Audio Playback Quality under User Prefs>General is set to high. Is there another setting that I may have missed?
    Thanks again for the reply!
    Bee
