Activity › Forums › Apple Final Cut Pro Legacy › importing jpegs/sequence settings
  • importing jpegs/sequence settings
    Posted by Mark Wilkinson on April 27, 2006 at 6:36 am
    i have huge number of jpegs ( a time lapse sequence ) to import and i am just trying to get the settings right. for my test, in PS i changed the pixel aspect ratio to DV and sized the image to 720 X 480. importing those into an FCP sequence with those dimensions and Photo JPEG as the compressor it wants me to render. i have tried pretty well every variation on the theme, each time adjusting the sequence settings to match but i cant escape the dreaded red bar and rendering should not be necessary.
    720 X 480 pixels DV and then square
    640 X 480 pixels DV and then square
    oddly enough, when i start with “Multimedia Large 4:3” preset from FCP
    it doesnt need to render and even more strange, the image appears in the sequence to be correctly sized.
    what is going on here ?
    Mark Wilkinson replied 20 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
